Ride Master
Check out the post (Do's and Do Nots" for new Spyder owners)
I would add a few suggestions of my own:
There is a tendency to lean into the corners thinking it will make the turning easier. I found remaining upright and not leaning into the corner, hugging the body with my inside knee and planting my outside foot on the outside peg works better.
Try it both ways and decide for yourself. One inexpensive mod is the Seal Pup floorboards, which lets the rider solidly plant his or her whole outside foot improves the turning. Also, keep the rpm between 4000-5000 in as low a gear that will allow that rpm range...use the tranny to slow you instead of the brake. If the rpm drops below 4000, downshift.
My best mods for mastering the twisties are the SealPups floorboards and, either adjusting the stock shocks to maximum or, Elka shocks. And check out the anti-sway bar
One of my friends put on larger tires (185/60R-14 Michelin Pilot Exalto A/S) from tire rack.com. Notice BRP increased the tire size on the 2013.
He has the standard shocks, anti-sway bar along with the larger tires and his RT turns easier than mine. Putting the tires on tomorrow.
The rest is learning to trust your Spyder.
