Marine 12V accessory socket
master1309
Purchased one on line comes complete with 36 inches of wire loom, fuse etc. I ride a 2011 RSS and know there are threads on this, but none in an RSS installation. As a disabled vet I could use some guidance on how to install this. Thanks in advance:pray:
Where..!!
Depending on where you want to have the outlet. The wiring is already there and connected to a fuse in the box. This if it installed in the frunk. Making a hole on the back of the frunk left side (sitting on the roadster) and installing the outlet there. You will have to remove the left center panel to gain acess to the wires to make the connection. There is a rubber boot that will go over the back of the outlet to water proof it. If you locate the outlet elsewhere you can go direct to the battery with the provided cables with inline fuse.
