Manual Air Shock
The saga continues, the dealer stated that this repair was not on warranty because, Corbin when they installed the heated seat, they tapped on one of the small fuses, and also made a small hole in the fuse cover. Therefore the dealer is stating that I had water going inside the fuse box and maybe shorten the 2 relays for the compressor. Now they are calling BRP to see if the compressor is on warranty. I am pretty sure if they tell them that I had water then I will have to pay for a new compressor. Except the 2 relays it showed a little of corrosion, all the other fuses were dry. Also the wire Corbin tapped to one of the fuses, the hole made in the bottom of the fuse box, there is no way you can get water inside. Our Can Am dealers in the area are not great, but also they will not help. I will wait for them to tell me BRP if BRP will cover the compressor on warranty or not. If not how much I should expect to pay for a new compressor and install. Thanks :banghead:
I was getting this also and then realized my horn and fog lights didn't work. Had developed a leak in the bag and it burnt out the compressor. Try the horn and if I'd doesn't work the fire is blown and you need to get it in. Mine was on my 2013 RT Ltd. I would think you must still be under warranty which is good. Mine was fixed under my extended warranty and with the labor and a new bag & compressor they charged $880.
