Lower Lip
NVR2L8
Looking for a few opinions on this subject.
The Lower Lip of the Spyder. Can it be cut off without a harmful result ?
This is the area in the very front end.
I just don't care for the look with that Lower Lip or Ledge on it.
If the front end where to come straight down. It would have a much cleaner
and sharper appearance.
As it is, it looks like a Snow Plow. To me anyway.
BRP, must have had a reason for it being there. Appearance can't be one of them.
My opinion is "No." I have never tested the airflow, but this portion sure appears to be designed to help direct airflow into the radiator and oil cooler. Seems like a rather huge modification to make if the results could prove to be disasterous.
-Scotty
it takes about 3 minutes to remove that lower front lip.
I don't know what it would look like without it,
but If I remember correctly it was about 4 of those push it screw things and two actual screws.
