bluestratos
I purchased some for my Suziki Burgman from DDM Tunning. I see that our bikes use a 9005 bulb style so I think the double set simular to the one pictured here should work in a 55 watt ballast: http://www.ddmtuning.com/Products/DDM-35W-55W-Dual-Motorcycle-HID-Kit. In my Burgman I bought the 35 watt versions and the light out put was slightly better than the factgory 55 watt bulbs and was an intense white color so I was very happy with them. I guess the Spyder RT moves the actual lens back and forth to create Ho/Hi beam correct?
Any one see why these would not work in this application?
As I said, I used these on my 650 Burgman and install was easy. The signal comes from a connector that mates up to the old bulb plug, power comes directly from the power source. The hi/lo function is achieved by moving the bulb back and forth. Since our lenses move in and out a standard 9005 bulb should be all that is requried to achieve the same effect on the Can-am which makes the kit even less expensive...$50+ shipping which if I recall last time was about $16.
Regards,
Randy
Regards,
Randy
