The RT of the future...
I think that I'd like to see the rear luggage compartments made a bit larger, The top trunk in particular needs to be reconfigured so that you can actually put stuff into it. Make it deeper ffrom front to back, and give it a lid that open us to give you full access to the space. Design it to hold one or more full-face helmets.
Same thing with the "saddlebags... make them much deeper, and configure them as toploaders. That way; nothing falls out at inopportune moments along the road! :shocked:
Give us better radio components, with controls that are a bit more intuitive too!
Bob,
That would be my guess where the next generation change will come from in the RT-S design.
I think the 1st gen RT-S (2010-2012) put the basic 3 wheel touring package out there (I consider the 2013 a 1st gen bike with minor modifications that would be found in the next generation). The 2nd generation RT-S (2014-2017) primarily introduced a significant drive-chain change but no improvements in seating and luggage accommodations. I almost think of the 1st gen Spyders as I would the Honda 4 cylinder GL models and the 2nd gen Spyders like I do the Honda 6 cylinder GL models.
It is my hope when the next iteration of the Spyder comes out, it will have continued refinement of the 3 cylinder engine but add changes to the rear of the bike to accommodate these changes:
1. Longer and wider saddle. Even with the factory comfort saddle which adds about 2" to the primary rider, it comes at the expense of the passenger rider. If you add a seat back for the primary rider, the passenger really gets cramped. They get cramped because the back of the bike didn't change. I would take a long look at the BMW, GL1800, Indian, HD touring model saddles and determine what the seat size should be. The average American adult size is getting bigger, not smaller. If we are to tour with our significant other, we need a seat that accommodates both of us in comfort. Can Am must get this right.
2. Luggage accommodation. Great job in adding a trunk in the original design; its that back packaging that fell short. For some reason, the design team must have felt the luggage space could not extend behind the rear wheel. Then, they added the thought, the side cases should open on the sides. If I led the design team, I would have followed the design of the Honda PC800. That means the rear would extend back beyond the rear wheel. The side cases would not be side opening, but from the top in a 1 piece cap that included the passenger seat (that way it is slightly elevated to help the passenger have a chance to see forward). The top lid would be assisted with 2 struts and could be remote operated from a remote fob like a car trunk. Because of the width of the bike, the side cases could be built wide, long, and deep enough to accommodate airline carry-on [fabric] luggage that we all have. That means they are designed to carry 40lbs each (not 20). There is no standard top case.
edit (like this):
https://lh5.googleusercontent.com/-eQP9GJ2VA_g/TXf1BaB47iI/AAAAAAAAAdU/OzfiW06CsLM/s1600/pc800ja.jpg
The passenger has a backrest standard. There is a factory option for a rear rack and this rear rack can accommodate an optional factory rear top case. The top case has the same features as a Givi 55 liter top case. It can hold 2 full face helmets side by side and then some.. Think of it as the place you use as you ride during the day. The top case has an optional factory designed rack for the top for more storage. The side cases hold your luggage for the night. Your wet riding gear are in the frunk along with other necessities.
3. Gas tank. Its volume is bigger because the saddle is 3-4" longer and the back frame design has been stretched; the gas tank is now 10.5 gals (9 + 1.5 gal reserve). And guess what, the shape of the tank is uniform because of all the extra space, so the gas gauge now accurately reads the amount of gas remaining. At 34 mpg, we can easily cruise 306 miles before hitting reserve.
2 closing thoughts.
- Direct fuel injection gets introduced further increasing the HP to offset the additional weight gain.
- For God's sake,
with the weight changes the Can Am guys finally get the suspension right by getting the proper rate spring front and rear. By getting the rear correct to include remote preload adjusters, they can ditch the faulty air suspension on the current bikes. The additional weight shifts the bike from a 55/45 weight distribution to a 50/50 so it has more balanced/neutral handling characteristics.
I know I am rambling, but I do think the next big change in the RT-S will be in these areas, so i am holding onto my 2012 RT-S and will wait for the 2017 model to roll out.
Jerry
