bjt
Very Helpful Member
what is that thing at end of grip?
Throttlemeister
i like the throttle lock types better. i wonder if brp vibration reducer and custom grips will work with vista cruise.
i understand that but vista cruise does not work with iso grips right?Vista Cruise has nothing to do with the grips you use. They grab the throttle sleeve and not the grip.
i was thinking if it does not work with one grip it may not work with others
if vista cruise does not work with iso, i was thinking about getting brp anti-vibration bar and their custom grips to go with vista.
thank you for info
i am not familiar with these things as i was a crotch rocket rider before i became spyder addict
one of website that sells vista had a note "will not work with iso grip"
i guess i can disregard that
there's a bit of confusion here. What lamonster installed, and what you're thinking of are two different products. The universal unit you're thinking of has a collar that slips onto the grip and little set screws nail it down. it also has a clamp on the bar, and a rod connecting the collar to the clamp. Pressing the lever down locks the collar from spinning.
The one lamonster is talking about goes on and acts as a wedge between the switch housing and throttle sleeve.
I've used the universal on iso grips in the past, but modified the clamp and connecting rod (drill and tap the bottom of switch housing- then use a little aluminium bracket). it sometimes can slip on the chrome of the iso, but if you tighten it up enough, it'll dent the grip.
Lamonster, do you have the PN# for the VC you used?
Diver
Diver
yes i do like this much better.Click here, this is it. Much cleaner look than the ugly universal one with the bar, clamps, etc:
http://www.spyderlovers.com/forums/showpost.php?p=44887&postcount=51
