Looking for a Grommet 2011 RTS
erinfire703
My new to me RTS is missing the grommet on the front panel (access to oil reservoir). Does anyone know where I can get a replacement, or the part number?
Thanks
The thick oval rubbery type grommets that the placcy pins on some panels slide into can be sourced fairly cheaply from cheapcycleparts & similar, or from BRP for not too much more! Sorry, but I can't recall any part numbers or their BRP name, but you should be able to find them on the parts diagram - doesn't really matter where you find it, they are either oval or round & once you've got the correct shape they are all basically the same size. Buy a few new, fit where necessary, & then either silicone them in or add a small zip-tie & keep the rest as spares - you certainly won't lose any more that way! :thumbup:
