Looking for 2016 RT Limited OEM part numbers for trailer hitch and trailer wiring harness, or aftermarket suggestions
Thefireman
Can-Am no longer offers a trailer hitch kit for the 2016 RT Limited. I believe I have found the original kit number for this bike but I cannot find the part number for the hitch. I believe the original trailer hitch and control module kit number was 219400432. I found instructions for this kit and the instruction say the Assembled Hitch number is not available separately.
My research indicates the part number for the hitch may be 705 203 210. Can anyone verify this is the correct number for the hitch and that it will fit?
I understand that many models and years use the same part numbers but the 2016 RT Limited may be unusual. For example, several online retailers offer a “Show Chrome Trailer wire harness for 2010-2019 Can-Am RT with part number 3902-0174” that fits 15 models, these include 2010-2015 RT Limited and RT Limited Auto but not a 2016 RT Limited.
The previously mentioned kit 219400432 lists three parts comprising the “control module:”’
1) Connection module 710 003 198 replaced by 710003903 Current BRP price is $174.99
2) Module harness 710 003 200 aka wiring harness 710003200 - must call BRP dealer for current price, not available online
3) Hitch harness 710 003 272 aka wiring harness at $76.22
When I search these numbers on the can-am parts finder website the site does not mention compatibility. And since Show Chrome’s harness is not compatible with a 2016 RT Limited I am concerned that some of the BRP control module parts may not be compatible.
Does anyone know which harness parts are compatible with a 2016 RT Limited? I have yet to find any aftermarket harness parts that fit the 2016 RT Limited.
Regardless if what the various OEM & a/mkt catalogues &/or parts lists might say, All of the 2010 to 2019 RT Spyders and all F3 Spyders with the rectangular swing arms use what is effectively the same 'OEM tow hitch', and there are really only minor differences between the harnesses too. There were some 2018/19+ Spyders that were fitted with a dodgy 'solid axle' instead of the earlier 'axle tube' that allowed easy installation of the tow hitch, which was mainly due to international supply issues and meant that some of those newer Spyders also needed a pre-2018 axle tube in order for the standard OEM hitch to fit, but apart from that, if it mounts to the swing arm it's effectively the same hitch, albeit possibly with slightly different add-ons or dressy buts to con you into thinking it's different - but it's not!. So if you are just after the hitch, then any OEM style hitch &/or clone of said OEM hitch will fit any Spyder RT or F3 with rectangular swing arms regardless of the year - you really don't need to be too concerned about part numbers or what the catalogues might say they do or don't fit. :sneaky:
However, the harnesses are a little different, and there are some confusing variations in the necessary wiring configurations that mean you either hafta find one that supposedly suits your year model; but beware, there are differences/variations in the way the Spyders have left the factory, and the catalogues aren't necessarily ANYWHERE near 'correct' when it comes to which harness fits what year/model &/or is installed/wired in any particular way - caveat emptor! Many often find that some 'customisation' is necessary, and it's basically a fluke if you happen across a true 'plug-n-play' wiring harness for your trailer &/or hitch! 😣
And all that brings me to this - because everything hitch/trailer wise hangs off the rear of the un-sprung swing arm, the OEM Hitches are really not the smartest or safest of hitch designs, and not only are they pretty damned expensive for the PoS that they are, they are renowned for causing all sorts of issues with the trailers they tow, their draw bars, the trailer contents, and vibrations etc. There are MUCH BETTER fully sprung hitch designs out there, hitches that generally cost a lot less and work a whole lot better in the long run, as well as being a lot kinder to your trailer, its structure, and its contents along the way! And there are alternative wiring kits to the OEM units too, wiring kits that still have the necessary 'full isolation' from the OEM Spyder harness so there's no feedback &/or canbus interference, which also tend to be better (and usually cheaper too) than the OEM gear. So I'd suggest that you seriously consider completely ignoring the OEM hitch & wiring kits, and get something a/mkt that very likely will be better in all respects - and probably work out cheaper too! :sneaky:
Just Sayin' ;)
Peter,
Thanks for the informative response.
And thanks for educating me on sprung hitches and unsprung swing arms. Can you direct me to any "sprung" hitches because Brand New Bombadier; Big Bike Parts (Show Chrome); nor Casa Home Brand mention sprung in their descriptions.
The following type of listings add to my confusion about Limited models: The USA Trailer Store lists a hitch but states it does not fit Limiteds:
  • 10-9075 Fitment:
  • 2010-2017 Spyder RT
  • 2013-2015 Spyder ST
  • (DOES NOT FIT LIMITED, LIMITED STS, OR RT-S)
Last night I contacted CanAmSpyderAccessories and asked if their harness was compatible with the 2016 RT Limited because they also sell Show Chrome accessories (but I could not find Show Chrome harnesses on their site). I said the Show Chrome harness doesn't appear to fit the 2016 Limited. Pierre called me this morning and said his fits the 2016 Limited. A 2019 post on this forum stated "The harness mentioned above from Can Am Accessories is not power isolated. So could cause hyper flash. Also if a short occurs in the trailer wiring. The Spyder lights will also fail, will cause faults and may cause Limp Home Mode to occur. The Show Chrome harness for the RT is power isolated."
The current CanAmSpyderAccessories harness description does not state if it is fully isolated - so how does one know if a harness is fully isolated? Perhaps the CanAmSpyderAccessories harness has been redesigned since 2019.
Peter,
And thanks for educating me on sprung hitches and unsprung swing arms. Can you direct me to any "sprung" hitches because Brand New Bombadier; Big Bike Parts (Show Chrome); nor Casa Home Brand mention sprung in their descriptions. ... < snip > ...
Any hitch that mounts to the Spyder FRAME rather than to the swing arm will be sprung, ie. it's mounted to a part of the bike that's being carried by the springs rather than mounted to something that's in direct connection to the road surface thru the wheel & axle. ;)
I'm sorry, but I can't really help you with the names/suppliers of 'sprung' hitches, cos I'm just not aware of any/all the local engineering or fabricating mobs over your way who might do them. I think you'll likely need to go 'custom', but here in Oz, every State has at least a couple of those engineers/fabricators who make this sorta thing, some better than others, but pretty much every one of them I've seen is quids and more better for your trailer and its the contents than the OEM unsprung hitch that's connected directly to the rear axle tube & swing arms! 🤨
Just a bit more on this, in the fairly recent past I've seen an increasing number of Spyders that've had OEM hitches which have ended up with worn swing arm bushes. Surprisingly enough, some of these haven't really done all that much towing, they've really just had the hitch mounted for a few tens of thousand miles; but I guess that's to do with the leverage hanging any extra weight waayyy out the back well past the axle. This is not really surprising when you think about it, after all, the swing arm bush is the first point of contact with the frame, and once you hook up a trailer, the hitch is pulling and bouncing and vibrating and sending all of that damaging stuff DIRECTLY into the very first solid connection point on the Spyder; and the hitch, axle tube, swing arm, etc are all just solid rigid links that help deliver all of that damaging vibration and load stuff directly into that one point - the swing arm bush!!
Because if this, I started looking at the swing arm bushes on a few Spyders fitted with frame mounted hitches, and none of them show anywhere near the same evidence of swing arm bush wear. Few showed ANY visible/measurable signs of wear in that bush! (Not even those that've done close to 200,000 miles and likely actually towed close to if not over 150,000 miles!!) Closely inspecting where their frame mounted hitches connect (generally onto the same sorta places things like passenger grab rails mount, or onto the main frame spar &/or outriggers/cross-members, the upright frame members that carry the rear seat cantilever, etc) generally shows maybe a little scuff type wear from the minor movement due to flexing etc, or possibly from a lack of regular checking/tightening of the mount bolts. I dunno about you, but personally, I'm a lot more comfortable with seeing a little bit of a rub or scuff on the frame from a well used mount than I am with a severely worn swing arm bush! 😖
Thanks again, Peter.
I now have a much better understanding of sprung versus un-sprung trailer hitches.
I searched for frame-mounted Spyder hitches and have found nothing listed for sale. I would not have a clue on where or how to find a fabricator to make a custom hitch.
I did find forum discussions from 2008 which identified at least three companies that made and sold frame-mounted Spyder hitches: Hannigan, Bushtec, and Les Produits-Denray, and possibly Lamonster Garage. Apparently, they all have ceased production.
Several 2008 contributors were concerned about the swing arm hitches putting too much stress on the swing arms, and wear on the swing arm bushings. Apparently, the swing arm designs were just hitting the market in 2008.
You stated “Just a bit more on this, in the fairly recent past I've seen an increasing number of Spyders that've had OEM hitches which have ended up with worn swing arm bushes.” Do aftermarket swing arm hitches produce the same bushing wear or is there something about the OEM BRP hitch design or parts that causes more wear?
@Thefireman, it doesn't matter what hitch mounts to the swing arm, OEM, A/mkt, or Custom; if it's hanging off the swing arm, it's conveying all those vibrations/shock-loads both ways - into the swing arm bush, and into the trailer! Something's gotta pay for this eventually, and while a number of trailers are breaking due to transferred vibrations/shock loads before the bushes fail, it's still becoming abundantly clear to most that the swing arm bush is still taking the bulk of the greater wear! 😖
As I said earlier, if you can't find an established A/mkt manufacturer who's retailing them, you will probably need to go 'custom'; and that likely means searching out a fabricator/engineer mob, possibly one of the smaller 'light workshop' operations &/or specialist trailer manufacturers that here in Oz, can be found in most light industrial complexes &/or the back sheds of retired metal workers/engineers. Sorry I can't be of more help... :oops:
I made my own wiring harness starting with one of these Bypass Relays from Amazon;
https://www.amazon.com/Towbar-Elect...2-fkmr2&keywords=Universal+7+Way+Bypass+Relay
Some Deutsch fittings from AliExpress; and some 8 core trailer cable.
To buy the BRP harness I was up for $900, while I struggled to spend $100 on the final item. There is a Deutsch fitting under the seat that has all your Trailer electrics available, which the BRP harness taps into. I have used the spare Relay port for my driving lights
Peter would it be possible to see a/some pictures of a frame mount type spyder hitch from down your way?
Too late, wet, and cold here to do anything tonight, but it just so happens that I've got one in the process of being re-furbished out in the shed, altho it's not installed on a Spyder, but I'm sure you'll get the drift. While it may not look like much, they're approved to tow somewhat more than the Spyder is legit to carry/tow, and the hitch is mounted on the frame in a number of spots, so it's all sprung load! (y)
I can probably get a picture of it for you and post it - maybe tomorrow... or more likely, the day after. Tomorrow's looking like being a fine day (after a string of dank and miserable days) so there's a good chance I'll be doing something else. ;)
Thanks Peter. The two risers, what do they bolt to?
They lean forward at an angle, a bit steeper to that shown, to reach the existing bolts up under the tupperware on the frame. When you present it to the Spyder with the tupperware off, it's been pretty intuitive as to where they bolt up on every Spyder I've seen so far, but I must admit that I haven't tried putting one on a 2020+ Spyder - yet. ;)
