Johndeeredoo
Hello All fellow spyder riders.
I got a good one.
I have a 2018 spyder RT Limited
The USB plug is in the frunk, but I want my iphone on the handle bars.
I was able to bring a lighting and a USB coupler cable from the frunk to the handle bars, but it will only connect to the BRP connect when the iphone battery is almost fully charged.
If I use a short lighting cable from the frunk, it works fine.
It also does not charge very fast too.
No matter what combination of cables I use, it just wont connect with a long USB cable when the Iphone is discharged.
Has any one used a powered USB hub on there spyder?
Thank you
JD
I got a good one.
Thank you
JD
