The laws of physics prevent you from having both distance and spread. There is a finite amount of light, that can be either aimed or disbursed. BRP chose to get the beam farther down the road, which limits its width...but the roadway is narrow anyway. Reflector-type lights do the same thing, but the light beams are not as parallel as with a lens, so more light is "wasted". This design is very common in European vehicles. The shutter system presents a huge advantage in this type of focused beam. It cuts off the diverging rays at the top, making a very flat beam that does not shine in oncoming drivers' eyes. If properly adjusted, this combination gives the maximum range of light with the least "glare" of any other available system.
Think of a flashlight, with its tiny bulb. In a lantern, it would barely cast enough light to read a page placed next to it, yet in a flashlight, you can see several feet ahead with that same bulb. If you placed a lens in front to focus the beam and cast papallel rays, you could see across the room. In a vehicle, we want to see down the road as far as possible, not light up the woods we pass by.
