Flamewinger
I was noticing that my RT wasn't starting like it should after a week or two of not riding. I found I had to plug in the Battery Tender JR to bring it back which took a day or a bit more before the LED turned green. When I first got the bike I could leave it in the garage for 2-3 weeks and the bike would start fine, no problems, but lately 4-5 days and it wouldn't start and recently, after 7 days, I turned the key and the lights were very weak. So . . . I figured the dealer didn't prep the battery right and I need to replace it. ( the bike has 7200 miles since the beginning of Feb. So I ride a bit and and do use the charger mostly in winter when its cooler.
Got new battery from Amazon $92. I also noticed the difficulty in getting the battery out once it was disconnected. It's heavy and makes for a pain to remove. I got a rubber tie down strap and bunched it up to form a handle and hooked the metal hooks into the battery terminals (ONE AT A TIME) and was able to pull the battery out easy. Helps in lifting it also.
