mark4Jesus
Did you by chance pump up the rear suspension? Sometimes that'll give ya just enough clearance. Otherwise drive it up on three pieces of 2x6, one for each tire of course. Then you'll be good to go. But, please put jack stands under it and let the weight down onto the stands to work on it. Also notice as you let it down that there is some side to side shift as the jack goes down...since the lift table picks up at somewhat of an angle. Keep a close eye on the rear especially since the lower shock mount isn't very wide. It's not worth the risk of having 1100 lbs on ya. :yikes:
No, I did not have the rear pumped up, I am going to check that and see, thanks.
