I have a different need to get under my spyder every once in a while. I like to get under it and just look at the condition of things underneath. I recently bought a set of Harbor Freight metal ramps to drive the front tires up on, in order to get enough clearance for installing the bumpskid. They worked great for getting under the front end. If I were to add a 3rd ramp and place it under the rear tire, while having the front tires aligned to the other two ramps, couldn't I lift the entire roadster up together? It seems it would be very stable lifting all 3 tires this way and also safe to work under, if you have the parking brake set. IOW, driving up 3 ramps simultaneously. Anyone try this method, just to get under the roadster periodically?
