lid locks and mirrors
I have the lid lox installed on my RALLY with the bar end mirrors. They were purchased from Lamonster. No problem with the install, I used the longer bolt that was supplied with the kit.
Yes you can. The stock mirrors have an insert into the bar ends that has a nut inside of it. You can use the same stock bolt for the LidLox kit. Just pull the bolt out and use the lidlox assembly as you normally would. Very easy
