Left turn signal won't auto cancel
Y Rider
For some reason each time I make a left turn I have to manually cancel the turn signal. Right turns will usually always cancel on normal 90 degree street turns. Is there an adjustment I can make or is this something that can only be done at the dealership? Is this another function of the steering angle sensor? It wouln't be that big a deal but it's a PITA to find the sweat spot to manually cancel the signals.
If you find a sweet spot you're doin better than me. :( Trying to cancel the blinkers after a lane change is the most irritating single thing about the Spider. I wonder sometimes what an idiot I must look to other road users as my indicators change left to right and right to left, when all I want to do is stop the :cus: lights blinking. :gaah:
How's your steering? My right turn signal wouldn't cancel right after the DPS was replaced, the steering center sensor was out of adjustment.
john
john
Steering seems to be fine. Now that I think of it this problem started after my dealer recalibrated the steering angle sensor in an attempt to solve a DPS Check fault I got. Guess I'll give them a call next Tuesday.
Have your dealer zero the steering sensors. If that doesn't work, they can troubleshoot further.
GeoffCee,
Since you guys drive on the wrong side of the road over there, please clarify left and right. Is left right and right left?
cougar
