LED reverse lights?
MisterP
Nothing showed up on a search. Has anyone converted the white reverse lights to LEDs? I have a 2014 RTL.
I found them at Auto Zone a while ago for my 2014 but at 13.00 each was not worth it. Not sure if they have dropped in the last year. Never followed up on it. Just take the bulb number to them, they will match it up.
Also try Batteries and Bulbs, they usually can get almost anything.
Yes
Hi,
Yes I have changed the reverse and also the turn signal bulbs in addition to the headlights and fogs. So all of mine are now LED's. Mine is also a 14 RT-S
Hi,
What was your source fo purchasing the bulbs? Auto parts house, perhaps?
Another source for LED bulbs is: Superbrightleds.com
I purchased LEDs for my rear turn signals as well as for all of mr car lights.
If you change your turn signals to LED's does it cause them flash faster, or will they flash at the normal speed?
Don
OK, I'll bite......how often do you drive in reverse any distance that you would need to change to LED's? LOL.......just kiddin'....but really....:opps:
