h0gr1der
I was being followed by someone who is motorcycle aware, and the first thing they said when we stopped was "can you put brighter bulbs in the turn signals"?
So, for those of you that have went through this phase of farkling, I pose a question, in two parts. Spyder is a 2018 RTL.
Which kit/brand has the most visible/brightest (in daylight) rear turn signals? I do intend to put the mirror mounted turn signal strips, I'm referring to just on the rear of the Spyder RT.
Which kit/brand has the most visible/brightest (in daylight) rear brake light? I don't think I want the brake light flasher, even though it's legal in all 50 states I have seen it cause a hassle.
I want kits that are known to work with the CAN Buss system and not cause problems, kind of tried and true models.
