LED lights underneath a Freedom Trailer
Has anyone installed led light kit on Freedom trailer?
The only concern you need to deal with is " are they waterproof " - the LED's and wiring connections. Nothing that I can think of makes the " freedom trailer " any different from any other trailer or for the Spyders themselves. All lites and wiring must be secure and I recommend a separate power source connection.... WHY ? ... if you have an issue with the NEW lites, they could cause a problem with ALL the trailer lites, causing you to stop using the trailer ... IMMEDIATELY .... and if you are away from home .... this could cause some serious down-time ...... good luck .... IMHO I would FUSE the new lites separately with a 5 amp or less fuse ...... Mike :thumbup:
