LED fog lights installed
Lew L
Well-known member
They are in and very bright. Right side is easy, left side not so much but not a project killer. Glad I did the change over and plan to do the LED headlights next month.
Kaos
Kaos
Seems like there's a lot more "stuff" to deal with on the left side. I discovered this when I removed the headlight housings to wire my turn signals down to the fender LEDs.
Glad you got it done!
Pam
Left side is a booger but can be done by just pulling the black cover on the left side and removing the cap through the top. The hard part was getting the lower tab back in. I would highly recommend doing the foglights the same time that you do the headlights on the RT. It's not bad at all then.
