Leaking brake fluid....
Chupaca
Found what looks like oil spots under my 2012 RS Sm5 27,000 miles. Would appear between the rear shock and exhaust crossover....
attachment.php
Happened a couple times so it was time to investigate. Did I mention I hate chasing leaks..:banghead: . Well pulled some panels
attachment.php
Suspected the shock but noticed that it was not leaking and the moisture was above the shock and the frame paint was damaged. Rough and bubbled. Brake fluid does that not oil...cleaned things up fluid was low so topped it off and placed a papper napkin around the cap to see if the caps are leaking.
attachment.php
But just letting those with what looks like oil spots under their machines know that it could be brake fluid...always good to check your level....:lecturef_smilie:
Tru dat
Don't overfill either, I think I did a long time ago, and it continued to leak until it got low enough to not leak.:roflblack: And that was with the vents pointing up hill . It is EASY to overfill.:yikes: Your pics are excellent .:thumbup:
Thanks..!!
interesting that they would not mention this on the cap. As much as they emphasize keeping the fluid level up you would think the cap would be marked with "top" "up" or an arrow. So you switch the to the 11:00 position and see if this solves the problem or if the level is also an issue here...:bowdown::bowdown:
interesting that they would not mention this on the cap. As much as they emphasize keeping the fluid level up you would think the cap would be marked with "top" "up" or an arrow. So you switch the to the 11:00 position and see if this is solves the problem or if the level is also an issue here...:bowdown::bowdown:
Chupaca
That is the what happened to me on my 2012, put caps on properly and no more leeks.
Cruzr Joe
OR THIS
Or maybe only have the cap able to be put on in one position only !!!!!!.........................Nah , that would make sense :roflblack::roflblack::roflblack:.....Mike :thumbup:
