Chupaca
Found what looks like oil spots under my 2012 RS Sm5 27,000 miles. Would appear between the rear shock and exhaust crossover....
Happened a couple times so it was time to investigate. Did I mention I hate chasing leaks..:banghead: . Well pulled some panels
Suspected the shock but noticed that it was not leaking and the moisture was above the shock and the frame paint was damaged. Rough and bubbled. Brake fluid does that not oil...cleaned things up fluid was low so topped it off and placed a papper napkin around the cap to see if the caps are leaking.
But just letting those with what looks like oil spots under their machines know that it could be brake fluid...always good to check your level....:lecturef_smilie:
