Latest Update(steering)from dealer
stgilmer
Update to
http://www.spyderlovers.com/forums/showthread.php?t=16202
Well after they have kept it and rode it a few times it started giving them check dps everytime they went to ride it. Brp has been contacted and the latest is that they are to change the gearbox sensor. Wasn't that only on the SE5, not the SM5?? I ask cause service sounded confused when she called me, thinking it was just on SE models that you change that on. If not, anybody else had that changed on theirs after having a new dps??
I don't know how everybody elses dealer feels but mine seems to love the input I can get from here.
Lamont: SAS was ok on it and steering was zeroed out, so that didn't help on mine. But she said it was a great place to start. Thanks!
I have 08 SM5 with GPS issue easy way to tell you bike well surge and you see the Gears going up/down on display without changing. if your going fast it'll show your going Reverse sometimes. good luck
Happy New Year
Ravi
Happy New Year
Ravi
Thanks Ravi, but I have never had any of those things happen. Had the surging but that stopped after the ECM update was done.
sorry to hear about the issues. Which model and year are you riding?
All the best... I hope BRP get A PROPER PERMANENT FIX.
Good luck.
1 more thing you might wana check is your battery under load test because mine was showing 12.9 V but under load it was 7.6
Good Luck
Ravi
Good Luck
Ravi
A question for you, was your load volt low from running ad ons?? If so, I have nothing added into the battery, bone stock there. Not even a power outlet(yet).
Update to
They might mean the GPS (Gear Position Sensor) which I had changed under warranty on my 2008 SM quite some time ago. Haven't had any steering issues since.
Same here: change GPS at 20K; DPS and steering with no issues at 62K (soon to be a 0K...:D).:thumbup:
I had the gps changed out a while back - way before I had my steering issue. 08 SM5 - around 9K give or take when my steering acted up.
And that alone leads me to believe that they are only guessing and not taking time to work it out.
I believe that each major part replaced, for the most part, is being sent back to BRP's engineering for a biopsy... to determine what's wrong... to find the root cause.
Any other path on their part would be a death march to insolvency.
I have to say that in my case you are wrong, til this day my old dps is sitting in a corner of my dealers shop. I ask was it to be sent to them for analysis, I was told no, that they had ask brp if they needed it sent to them and was told no.
I have to say that in my case you are wrong, til this day my old dps is sitting in a corner of my dealers shop. I ask was it to be sent to them for analysis, I was told no, that they had ask brp if they needed it sent to them and was told no(discard of it).
:yikes: :dontknow:
Thank goodness it's a vast minority of owners who are having problems...there will always be problems with any new piece of sophisticated machinery...hopefully BRP will work hard to correct problems...I don't think they want disgruntled people out there but there are some problems that will go without explanation...
I am sure there is several of us on this site that would love the opportunity to take one apart just to see how it is made.
Commercially sensitive information...:dontknow:
If you had the steering problem, would you still feel the same way?
It's been almost a year now since the one forum member (that I know of) had their serious accident, which appeared to be steering associated, and BRP is no closer to solving the problem. So, does that fall under- "but there are some problems that will go without explanation"; if it does, that's not very comforting, even to those that have not had the steering problem yet.
