Lamont Ram Ball Attachment to Dash
I tried the toggle bolt idea and the nut with a washer but in both cases the ball will still roll left and right. I actually sanded the back of the ball plate to matche the shape of the dash but even that did not help. Looks like I need to take it a step further, possible a tiny pin throught the flange to lock it in place.
Ram ball ?
I loved Lamont's idea of attaching the Ram Balls in the two corners of the dash. He said he had some problems getting the nuts on, had to bend a wrench, etc. Well I sure know what he meant, lost several nuts, got frustrated and came up with another idea that was painless. I purchased the smallest butterfly type bolts I could find and used those. Took just a few minutes. There is plenty of depth in this corner, but near impossible to get anything but one finger to hold a nut. With the butterfly bolts this took no effort other than drilling a bigger hole, no need to try and hold a nut, etc. I am using the right side for my iPhone that with the 3" arm is the perfect position to take video, and the left side for the ram cup holder that is back ordered.
Is this a Ram ball that already has a hole in it or are you drilling it? Part # if already drilled?
Just a heads up, on my 2012 RT-S I was able to mount the Ram 'B' ball (RPR351WBBF) to the dash without too much issue. I did one side at a time.
I removed the speaker grill. I drilled out the Ram ball for a 6 mm stainless allen head bolt (beefier). I placed the 6 mm bolt thru the Ram ball mount. I drilled the corners of the dash where this threads shows it. I used my small finger to very carefully hold/place the nut behind the dash, going thru above the top of the speaker area. I then slowly threaded the bolt into the 6 mm nylock nut. I was easily able to slide a 10 mm wrench (open/box end) behind the dash by simply popping off the mirrors, unbolting some of the tupperware. There were 3 bolts under the mirror, the 2 bolts for the the side you're working on below the headlights and carefully pried the front trim and upper side tupperware (no need to pull it off) to expose the slot that you can slide a 10mm wrench to hold the nut. I used a 4 mm allen to tighten the ram/bolt thru the nut. Worked great, didn't need to bend any wrenches or drill a larger hole to for this thread's toggle bolt.
Oh, also be sure to place a towel or rag over the speaker cavity to catch any drill shavings or a 6mm nut you may drop doing this.
I did mine similar to yours, but I pulled off the mirrors and the tupperware to work at it from the sides. I didn't need to remove the speaker grills. I did have a problem getting the large flat washer and the nylock nut to stay in place behind the dash until I could get it threaded on the bolt. I wound up using my fingers and a magnetic tipped wand that I use to fish out screws and nuts that fall into small dark holes. The magnet held the nut and washer while I threaded it. Once threaded, I used the 10mm wrench to tighten the nut while I held the Ram Ball with the bolt in it.
