BajaRon
Well-known member
.....What relationship does " SHEAR " have in regards to oil filter changing .....ie. If BRP says 9000 mi. on OIL & FILTER can you change the oil at 4000 mi. and keep the same filter till say 9000 mi. or is this just " stupid ":yikes::yikes::yikes:...............Mikeguyver :thumbup:
I agree with ulflyer. There isn't any relationship. The filters are there strictly to keep contaminants out of the oil system. They only catch solids though, so liquids like fuel and water go right through them. Of course you're not supposed to have fuel or water in your oil, but a little is always present (at least when cold) and it doesn't really hurt anything.
Think of a tire. You have belts made of cords (usually steel or an Aramid fiber) which supports the tire structure. These materials are strong but will give you no traction. So you add rubber over the top. The rubber both protects the belts and give you traction with the road surface. But what happens when the rubber wears away? The fibrous materials are exposed and they are no match for the pavement. They don't last long, and then you have a blowout.
In most synthetic oils, the structural fibers would represent the oil molecule chains and the outer coating of rubber would represent the additive package. As long as the additives are doing their job, the oil chains will hold up pretty well. Once the additives go away the oil chains don't hold up very long. They wear quickly getting thinner and thinner.
This is the 'Shear' or thinning of the oil viscosity that you really don't want. Instead of a 10w-40 oil, you may be running a 5w-30, 25 or even 20 weight oil. This will not protect your metal to metal parts and you'll start to get wear.
And that's where your filters come in. They will screen out these metal shavings and keep them from circulating in the oil. But the idea is to NOT have metal parts rubbing together creating these shavings in the 1st place.
