Knock off or BRP hitch ?
Last thing I want to do is burn up the Peter, sounds to me that BRP is trying you make you buy a RT622 or a Freedom trailer?
I would hope the BRP product would avoid that happening my Yamaha Venture and Victory Cross Country used the happy isolator, no issues plulling the same trailer. If the BRP product dosent prevent any back feed what reason would we use it? I just purchased a 2016 leftover RT Limited and I'm waiting on the BRP hitch and plug and play electrical to come in now I'm on the fence as to what to do
BRP uses the Hoppy Circuit Guardian isolator.
knock off or BRP hitch
OK, if this is the case when you look at the information on that isolator it says that it's re settable and multiple use for more than one instance of a short occurring.
Now having said this, why are there multiple instances of individuals on this forum replacing their isolators multiple times??? I'm easily confused about things electric.
:opps::opps::opps:
Al
:opps::opps::opps:
Al
It has an automatic self reset function. A short in the trailer is not going to cause any harm to the unit. The fuse will blow protecting it. Fix the short and replace the fuse no harm done.
In the cases that people have complained that they have burnt out their isolator and it has been blamed on the trailer wiring. The fuse is still intact. The problem is not a short. The problem is a bad intermittent connection. It does not matter if it is a BRP trailer or aftermarket. It can happen on the ground or the power side of the circuit. The electronics in the isolator cannot stand up to being turned on and off hundreds of times per second as the trailer bounces down the road. You have probably followed a trailer down the road with its' lights flickering. That's what kills the isolator module.
Ok this may sound stupid but who is Pierre? Secondly I used to pull a trailer behind my Victory it was a 5 flat, I've just retired it back to 4 flat I hope my new 2016 RT Limited will work properly with the BRP wiring set up. If not I will have to try something different.
His accessory outlet is www.canamspyderaccessories.com.
Pierre is SpyderTV.net and Can Am Spyder Accessories. They are in Canada but he comes down here to many of the Spyder events. He was at Red Rocks last year and I think he is coming back again this year.
Wiring harness 2015 freedom trailer
Hitch and control module on its way from BRP ... Hitch will be no problem .. Little worried about the wiring .. Going to attempt myself .. And videos ? Installation manuals out there ? I have a 2015 RTS trailer is a 2015 Freedom trailer
Send links !!!
Intructions ... not so good
Send links !!!
Hitch n module just arrived .. whoa instructions look horrible !!
Hitch
I bought an aftermarket hitch off eBay for my 2011 RT Limited, bolted on exactly like the OEM hitch and was removable like the OEM hitch, cost half the price. Also bought an aftermarket tail light converter and wired it to OEM connectors from Tricled so it was all plug and play NO splicing (hate cutting into the harness). Wired it to a standard 4 pin to hook up to a Harbor Freight Tag Along Trailer and no problems, I did have to change the lights on the trailer to LED's.
