Lamonster
SpyderLovers Founder
I ran 20 up front and 30 in the rear on the last set. I'll have to play with these a bit. If you run them too low they get hot.Lamont,
How much pressure are you going to run?
Hmmm, did some research and not a whole lot of choices out there for the 225/50/15. I was hoping Perelli made something but if they do I didn't find it. I did find these interesting alternatives.
As I'm sure you know under inflated tires cause heat. I would keep an eye on it. 30lbs worked great for me.:dontknow:I ran 28lbs in the rear and the middle of the tire was bald before the outsides of the tire was half gone. I just now changed to 21lbs in the rear and it rides so much smoother it is truly amazing.
Lamonster - should I be concerned about the tire heating up and causing blowouts?
I used 20/30 as well and got 15k from my back tire, fronts still look greatAs I'm sure you know under inflated tires cause heat. I would keep an eye on it. 30lbs worked great for me.:dontknow:
dltang and I both had Ecsta ASTs put on last week. So far so good. lamonster posted about riding in the rain with his the other day and said they worked well, maybe better than the stock Kendas.
Lamonster,
How did the Ecstra AST rear tire work out for you?
I need to replace the rear tire because the center is down to the wear bars. I got 14k out of the first and +15k out of the second Kenda. I am thinking of switching to the Ecstar if you had good luck with it. Tire Rack has them for $60. Are there other car tires you would recommend? I need to replace it before Spyder in the Smokies.
Thanks for hosting the website and for all the information
See you in September
:doorag:
I think I'll be ordering this tire again too. My last Toyo last the same as this one but cost twice as much.I know this isn't addressed to me but I do have experience with the tire in question also...
I have been running with the same Ecsta AST since I posted that I had it put on my Spyder in April 2009. Close to 20,000 miles on it and I'm still riding it though it's not quite as good in the rain as it once was because I'm down to the wear bars now. FWIW, I have the replacement Ecsta AST in my garage right now waiting for me to get it installed (happy enough with the tire to put it on again).
I have about 600 miles on my new Ecsta and am very happy with it. My dealer had never seen a car tire on a Spyder and thought it might throw a fault code...............:hun:Only have 10,000 miles on my original tire, and should be able to get at least another 2,000, Thanks for the info. Just ordered my Ecsta AST from Tire Rack, $60. plus shipping :yes:
