dabreitbach
Hows this for the 6000 miles service. Went to dealer about two weeks ago for service and also had a vss code showing up. They did the gear shift update and parking brake update. The update did not fix the code problem. They did the rest of the valve check ,oil change ext. and since it was running way late in the afternoon and I had to get going I had them give me what buds readout and I have the shop manual so I told them to call brp and I would try to solve it also at home. I should tell you I am about 90 miles from the dealer. The tech had me come and listen to the motor when he started it because it did not sound right to him. I didn't hear anything different so he buttoned it up and away I went. I get home and there is oil all over. They pinched the oring on the oil filter housing. So I fixed that and got on to the trouble shooting. Turnde out a tail lite bulb was working but throwing a 3 goofy vss codes. Go figure. Fix that and call and tell them that I fixed it and could they send me an oring to replace the bad one. They send me an oil filter instead:dontknow:. So I go dig up an ring at the hardware store and save the filter for the next change. I clean off all the oil and go out for a ride and dinner last weekend. Its running okay but not great. I think Its just from sitting all winter.
Get home and more oil leaking again, not the oil filter housing but the front valve cover. So I fix that yesterday and as long as I have the valve cover off I put in new plugs. I fire it up today for a ride and after i ride about 3 miles it starts backfiring thru the front throttle body. It is sort of spitting like the timing is to far advanced. I check my exhaust gaskets thinking I'm sucking air. No the are good an while I was fast Idleing it the front header pipe starts glowing cherry red for about the first six or 8 inches of the pipe. Well this ain't good. I shut it off, load it up and run it up to the dealer.:gaah: They will look at it monday. It is throwing no codes and it wasn't getting hot. I thinking the valve cover gasket was over heated and that would explain that leak.
Any ideas? I'm thinking a burned valve from something done on the valve check. They said it needed no shimming. This was their first valve check. Could they have messed something up. In their favor they are a big kow and yammi dealer also snowmobiles and water craft and 4 wheelers in those brands and also seadoo skidoo. I am stummped and not real happy.
Can Lamonster or anybody else have any ideas?:dontknow::dontknow:
Sorry for the long post.
