J&M CB Antanna Upgrade Kit
SpongeBob
Has anyone tried the J&M CB Antenna Upgrade Kit ?
Is the antenna longer?
Any noticeable results for the money ?
I'm having the CB communications installed when the '14 arrives and that would be a great time to put in the J&M kit if it's worth it.
Thanks ...
I did on my 2010. It's the same length but better made. My reception went from useless to barely useable so it was worth it to me. Same here, I will install the J&M antenna on my 2014 when I buy the CB.
Yes have them on both my spyders and work great. But if you know any one with a meter you can fin tune it more, but out of box works better then brps. You can make a bigger ground plat for it to and then really works great, put 2 grounds on it to.
How would you get additional grounding ... a braided wire ... foil ?
I did not opt for the CB communications on my '11 RT-S, nor have I had it on my Wings.
Might as well make the best of it since it's a pricey option.
I made a plate that fills the hole area in so that the new one sits in the center of the plate. Grounds wires go to the farm in 3 ways 1" in size and works great. Also did it for my ham radio to and am fm.
Sorry but bike is down, but will get new picks up soon, 2014 will be here in few days then will have a great vido on my build radios ham, cb
