eddieshep999
He appears to be " Mechanically Challenged???:roflblack::roflblack::hun::hun:
Thats just nut's !:joke::joke::joke:
Arrived, installed and tested!
All I can at is OH MY FREAKIN' GAWD! THIS THING IS AWESOME, A MUST HAVE FOR ANY RT OWNER!
I noticed a difference from the first right hand turn in my neighborhood at 25MPH and it only got better in the twisties!
I took an unfortunately short ride in some of the twisties I am most familiar with and the difference is amazing! Turns that uses to put a little fear in me where smooth as glass at higher speeds than ever before.
I do see one downside for Ron though, he is probably going to be selling fewer brake pads as a result of this amazing performance enhancing product.
Well done!
\\you are right got the swaybar. put it on and was not hard at all. my wife and I could not believe the difference a swaybar could make. it is a must on rt. my wife has a 2012 spyder rt a/c. she has had it for about 2 monthes we were taking 40 mph curves at 49 mph and couldn't tell it. just have to watch my speed on curves now. worth every penny for the cost of the bar. had front tires at 30 lbs and shockes at 5 after putting on swaybar now front tires at 25 lbs and shockes at 3. rides so much better.
thanks for info. i'll try it at 4 ,we've only got 2000 on it and the mechanic said tires wear on the inside of the spyder,25 Pounds is a LOT according to 100,s of posts on the Forum?? I think if you tried 20 Pounds with the stock shocks on 4 or even 5 and the Sway Bar you would see a BIG difference.
The manual says #4 Shocks =200 pound rider and cargo!
#5 Shocks=Rider, Passenger, and Cargo!
Just my opinion.
Mechanic is full of baloney. That is the standard answer, but the truth is that a Spyder whose tires wear unevenly on the inside of both front tires is :thanks for info. i'll try it at 4 ,we've only got 2000 on it and the mechanic said tires wear on the inside of the spyder,
have you heard anything differently? this is ringalls with wife here signed in,so hopefully i wrote what he wanted to say.thanks again, in the process of learning about our spyder open to any and all info.
Only got 2000,on it since we just got it in oct, the spyder mechanic said the spyder tire wear down on the inside of the tires so thats why we're trying the highe pressure, have you heard anything differently? this is ringalls talking thru wife since I'm on at the moment. thanks for the info.always open to more info.\\
Wow, you run really high pressure in your front tires How are the tires wearing?
Thanks for the info. will do...mechanic is certified by BRP "master" maybe he misunderstood our question when asked:banghead:Mechanic is full of baloney. That is the standard answer, but the truth is that a Spyder whose tires wear unevenly on the inside of both front tires is :
a. Overloaded without the front spring (shock) preload being set high enough,
b. Misaligned, with insufficient toe-in,
c. Running inadequate front tire pressure in combination with aggressive riding,
A correctly aligned Spyder with the front suspension in good shape will wear the tires evenly, and the fronts will last 20K or more. At 22K mine are only half worn. Check your front preload, and set it higher if needed. I recommend one notch above the recommendation in your manual for your weight, passenger, and cargo load. Be sure your front tire pressure is even, and high enough. The 15 psi in the manual is too low for most riders. A good place to start is 18 for an RT and 20 for an RS. If all else fails, find a good shop, that has experience with front end alignment, and have it done (after a thorough front suspension inspection). If your Spyder tends to follow every bump and bank in the road, and you are not holding the bars too tight and overcontrolling, the chances are it needs an alignment.
Ron I've got to say that the sway bar is fantastic. I got in a nice ride yesterday on some curvy roads and the new bar upped the fun level several notches! I'm hoping that the Owner's Event is in Durango again this year so I can give the Million Dollar Highway another run.:2thumbs:
I've got the bar, waiting on the "bump skid" and plan to do both installs at the same time (since the Spyder will be "up" anyway). One thing that I cannot find are torque specs for any of the bolts in the install. Near as I can tell, there are 8 involved (4 on the bar, 2 at the heim joint, and 2 to loosen the frunk). I've checked the BRP 2012 RT maint. manual (on CD) and all it shows are instructions on removal and replacement, no mention of torque for any of the subject bolts (though I see torque mentioned many other places in the manual).
Does any one (Ron, maybe? :bowdownhave a recommendation for each of these? Also, for the two collars that go on at the end of the install, would there be a recommendation to use loctite on those small screws?
Looking forward to the improved ride and keeping up with SpyderCowboy on his HD Ultra Classic!![]()
Here is link to the install album
