Issues with Spyder
Tigger
We have two issues with leaks.
1. Oil coming from Airbox and dripping on radiator on right side
2. Coolant dripping out right side.
Are these common issues? Still under warranty, but hate taking to dealer if it is something I can fix.
Oil in the airbox has been a common issue with the RS in the past.
Coolant leak not a common issue as far as I know.
Very common, And easily fixed, Do a search on blow by and radiator leaks, Then you can fix it yourself
or give the info to your dealer and let them take care of it..
Oil in air box is a common problem. Try not to over fill the oil to "help" prevent it or there are a couple of modifications you can do to prevent it entirely.
Coolant is another story and should not happen. This is another well known issue and could be from a few things. Cracked coolant reseivour, loose clamp or it could be from the weep hole on the water pump. All three need to be checked and fixed if needed.
Oh! That coolant cap is a :cus: to get re-installed correctly. I think that you've got to twist it intil you reach the second detent... :shocked:
oil in the air box
IS NOT a normal thing
IT is a common thing with RS
and is not ALWAYS from over filling
mine sits in the shop they said i over filled it that's why it puked a quart into the air box
my front cylinder has a pressure of 95 and rear has 205 sounds to me i have something else going wrong here
so oil in the box is not ALWAYS a over fill thing can be a serous condition
Issues..!!
Agree that the oil is common but only in small amounts. The coolant not so much. Check the obvious, radiator cap hose clamps and the weep hole at the pump. The cap and clamps are easy the rest not. :dontknow:
The coolant dripping on right side could be the reservoir bottle crack (common for a 2 years old RS).
See the 2012 upgrade for that part.
A good resolve for the oil in your air box is installing the kewl metal air intake kit, problem solved, issues i've heard about leaking coolant could be as simple as a hose clamp not tightened or positioned properly. Good luck hopefully everything works out for you:thumbup:
A good resolve for the oil in your air box is installing the kewl metal air intake kit, problem solved, :thumbup:
Correct me if I'm wrong, But unless you plug the crankcase vent hose [don't do that] your just injecting the blow by oil into the throttle body's , The blow by is still going on. You just moved the oil from the air box to the [cylinders] engine.:dontknow:
Finally got around to picking :spyder2: up from dealer. They said no oil leak, but a coolant hose on the water pump was loose. I'm going to keep a lose eye on this as do think it was oil from the Airbox. They also cleaned the VCM connections as there were voltage failure codes thrown.
The oil blow-by still goes on, but routed directly into the throttle body..., not pooling in and spilling out of the huge air-box and onto the engine and radiator.
I had to install the KewlMetal air intake in my 2009 SE5 to resolve the oil-spilling problem and, as an additional "bonus", I gained unrestricted access to the front cylinder spark-plug and upper engine sections (for cleaning / maintenance / repair purposes).
It is a little noisier now when you open the throttle, but coupled with the Hindle roar, it still sound like music to my ears... :thumbup:
:thumbup:
:thumbup::thumbup:
By the way..., I tried the sponge in the breather hose first...; but it got clogged, and the resulting built-up pressure inside the engine cases caused oil leaks thru the drive-shaft oil-seal and other minor places... :yikes:
