Is this normal
robhowen
The included photo is of what I believe is my 2015 RTL 1330 Air Intake Manifold. You will see arrows pointing to a hole. This photo is taken from the right side of my RT. What I'm trying to find out is if this hole is normal or abnormal (defect). I squirted some brake cleaner in there while it was running to see if the running changed. It did not.
Can someone tell me?
Regards,
Rob
It looks like a reinforcing rib has been broken. Here's a pic from when I did my spark plug change. It's not from the same viewpoint as yours but I think you can see the difference. Look at the left side of the pic where you see the same two bolt heads that you show.
