Is there a way to remove a Ryker's handlebar braket/lock screw?
JonteRaynal
Hello, all. I now have a big issue. For a few weeks now, my handlebars have been sliding up and down while I drive. I knew to tighten the screw with a flathead counterclockwise, but that didn't help this time, so I attempted to remove the clamp and screw. The screw won't screw out. It wiggles up and down but it's locked in. It's kind of stripped now and seems impossible to put the clamp back on. I have no room/leverage to put the clamp back on because the screw seems short. Is there a way to remove the screw or remove part from the sliding bracket?
EDIT: After taking a closer look at it, I need to remove the bracket in order to remove the screw. The screw is pretty stripped. The problem is, how do I remove the bracket? I unscrewed the 4 screws, detached the handlebars, removed the center screw on the bracket, but the bracket doesn't slide/come off?!
Made any progress? After a quick peek at my bike I'm thinking the bracket may be part of the frame. Can you post a picture for us?
Sarah
More Information on Steering Cluster
Here's a blown-up view of a 2019 Ryker from https://www.canamseadooskidooparts.com/ Rykers are listed under Roadsters. You most likely will have to drill out #435 and 305. The steering column #120 does come out, but you may have to detach the cluster #130 first. You may be able to feed #305 in after twisting #120 over to one side. Make sure #120 is very loose first. You will have to order #435 & #305 parts. Go by your parts list for your year Ryker. When reattaching, I believe the stem bolt #702 has a torque spec of 18 lb/ft. I hope this info steers you in the right direction!
