JonteRaynal
Hello, all. I now have a big issue. For a few weeks now, my handlebars have been sliding up and down while I drive. I knew to tighten the screw with a flathead counterclockwise, but that didn't help this time, so I attempted to remove the clamp and screw. The screw won't screw out. It wiggles up and down but it's locked in. It's kind of stripped now and seems impossible to put the clamp back on. I have no room/leverage to put the clamp back on because the screw seems short. Is there a way to remove the screw or remove part from the sliding bracket?
EDIT: After taking a closer look at it, I need to remove the bracket in order to remove the screw. The screw is pretty stripped. The problem is, how do I remove the bracket? I unscrewed the 4 screws, detached the handlebars, removed the center screw on the bracket, but the bracket doesn't slide/come off?!
