Rattlebars
Putting a resistor across the + & - wires seems to negate the voltage savings of an LED.
Asking for a friend...
When SpyderPops installed a bunch of LED's I had the hyperflash and he somehow he punched some buttons on the left controls on the handlebar and stopped the hyperflash. I don't remember the correct button sequence he did though. Maybe someone whill chime in shortly with the answer.
Somewhere on this forum, was posted a reply that said the linked bulbs will stop hyper-flash. I don't remember where it was posted, but I did write the link down so that if I ever needed it, I could order some and try it. I have no idea where the thread it was posted on is now.
https://www.amazon.com/EverBright-E...w+3014+chip+set+144+smd&qid=1595617762&sr=8-1
I might be the one that posted about those bulbs. I was hoping that the "no CAN-BUS error" meant "no hyperflash", but was also prepared to take other steps, if necessary.Somewhere on this forum, was posted a reply that said the linked bulbs will stop hyper-flash. I don't remember where it was posted, but I did write the link down so that if I ever needed it, I could order some and try it. I have no idea where the thread it was posted on is now.
Did you try the remedy with the engine running? That is what worked for me.I just put those LEDs in my 2018 and they hyper flash. The programming for earlier models does not work.
I did not work for my 2018 RT-L. I am returning to LEDs to Amazon today, unless someone comes up with a program sequence for 2018+ Spyders. I do not want to install resistors and that defeats one of the advantages of LEDs.
Yes, you can certainly save some energy by switching to LEDs, but on a Spyder, it's irrelevant. The alternator is capable of putting out so much more than the bike needs, so there is no need to scrimp on a couple of amps here and there.I do not want to install resistors and that defeats one of the advantages of LEDs.
There are advantages to LEDs that are a bit more important than energy savings.
1. They light up quicker. Depending on the bulb/LED, it might be up to half a second quicker. "Half a second?" Yeah, it's not much, but every little bit counts.
2. They usually last a lot longer.
3. If proper LEDs are used, they are usually brighter.
4. They cost more money, so you can justify bragging about them. :thumbup:
