Is the Accessory wiring hot all the time, or key activated?
5Wheels
I know I can check this myself but many of you already know; 2020 F3L: are the connections under the left access panel and under the passenger seat hot all the time, with the key on or only when the motor is running? TIA
Hot with key on only. If you are adding electrical whatevers, I would install a fuse block. Mine is powered through a relay that uses one of those wires.
By now you've probably already discovered that the one under the left panel is hot ONLY with the motor running. I forgot that quirk and thought I'd blown a fuse since there was no power with key on. I can't speak for the one under the passenger seat but I'm guessing it is the same, hot with motor running. I wired in a 12V outlet in the frunk that is hot at all times, wanted it for a tire pump that I hope I never need to use.
