Is this LH Multifunction handlebar cluster button connected? Will anything else fit?
mike519
On the left handlebar underneath the "joystick" control on my 2019 Spyder F3L is a blank covering a hole, and that cover is removed, I can see the softpads for a switch. I assume this is for volume control, as I have seen it in other pictures. I assume this was part of an optional package.
1) Is it already connected to the head unit, so that if I install a switch, it will control volume instead of using the PIA joystick?
2) OR, can I use this space for a switch when I install another accessory like fog lights? It would be good if I can use the wiring already installed behind those softpads, but I need to know where to connect inside the dash (Yes, I can always use a multimeter and track it down, just thought I would ask in case anyone else has done that.)
Thx
On RT's that lower switch is to raise and lower the windshield, same LH Multifunction handlebar cluster. Don't know if the F3 wiring is the same up to the cluster though.
RT's LH Multifunction Cluster
F3's LH Multifunction cluster
Thanks, will see if there is wiring around the windshiled and see if I can find continuity with the wiring in the cluster. Thx
