I am wondering about a few things on the Spyder.
I have noticed a few things that don't seem to add up
1. Everyone is talking about Juicebox when you change the exhaust and or the intake. I don't understand why this is necessary as the system in the spyder should automatically adjust mixture to compensate... This is after all one of the reasons for fuel injection.
I can see a Juice box or such to get through any odd dips in the power band If you were going to do this you would need to have the Juice Box Pro so you could adjust each rpm range seperately...
Am I nuts? I have the Hindle and My Spyder runs great. I have yet to read the plugs, so I can't swear it is not lean but I just don't understand this..
I am definitely not a fuel injection expert but isn't this what all the sensors are on there for?
2 Can-am talks about how critical it is to have proper belt tension and you must use their $1000 gizmo that checks tension by sound and that if you don't you will have problems. Then suddenly they decide to cut the recommended tension by 2/3.. How critical could it be? I have never had issues with a belt just make it good and snug make sure it isn't jumping on the cogs....
Now I am reading that they lowered the belt tension because they were destroying the bearings... Hmmmmm... So we cut the tension by 2/3.... this seems to be a knee jerk reaction. Now I am seeing idler pulleys to help get rid of the vibration.... Hmmmmm again.... How about enough tension to eliminate the vibration and loose enough not to destroy bearings.......
Anyone out there doing their own tensioning on the belt?
3 It seems like there are a lot of custom accessories available. I consider this a great indicator of a Cycle/Vehicle which is really popular.... Yet it seems they aren't as popular as they seem since I never see others on the road.
For some reason people who make custom parts for the Spyder don't seem to know how to take good pictures of their product which help you know how it will look installed nor necessarily write a description which actually identifies what the part does.... Why is this?
