Is Belt Tension highest with rear wheel on the ground, or raised?
DaniBoy
Is the belt tension greatest when the bike is on the floor, or with the rear wheel up?
Mine is measuring 140 lb on the floor. It’s aligned beautifully so I kinda hate to mess with it.
when in the air, the belt starts to lose the highest tension. with the wheel off the ground and shock full extend, the belt can be walked off. the tension of 140 on kricket is a tad low at 140, but still able to run. i run mine at 160-165 on ground as do others
You have a 2010. People will forget that the 2008 - 2012 Spyders have a lower spec than the newer models. Yours is perfect.
