Integrated brake/signal kit for Givi/BRP hardbags?
asp125
I've seen threads about the Custom Dynamic or ESI kits for Givi/BRP bags that turn the red lens into brake lights. Is there a similar kit that makes them into integrated lights? Kind of like the Triple Play kit does for the stock rear lights.
We have the full Givi sidecase/topcase combo and I want to make all three of them part of the rear lighting solution.
When I added the Givi side cases I rigged some after-market turn signals I got from the local Cycle Gear:
http://www.cyclegear.com/SPEEDMETAL-Micro-Arrow-Turn-Signals
For the top box I added the light kit from AdMore:
http://www.admorelighting.com/top-mounts
I added a red side-marker light I had left over from a trailer as another brake/running light between the turn signal lights.
Went to the craft store and bought a bag of plastic jewels, (carefully!) put three holes in the box (lined up with the bulb) that holds the license plate lamp and super-glued the jewels over the holes for another rear tail light and side lights.
I also added some red conspicuity tape inside the clear lenses on the back of the side cases, works pretty well.
I see in the picture the top case is not illuminated, these pictures may be before I got the AdMore kit.
Let me know if you want any details or more pictures.
Charles
attachment.php
attachment.php
attachment.php
Admore also do ones for the Givi v35 panniers and they have a fitting kit for Spyders (these would also work with the BRP panniers). Two sorts available:
Rear and brake lights:
http://www.admorelighting.com/side-mounts/Givi-V35-Side-Case-LED-Light-Kit-TS
Rear, break and indicator lights:
http://www.admorelighting.com/side-mounts/Givi-V35-side-case-bi-color-LED-light-kit-RY
Haven't got them myself but have seen them on another bike and they worked well.
Looks like the second Admore kit will do the trick. Thanks. Does anyone have actual experience with these and are they plug-n-play?
Admore Lighting
The Givi Top Case and Side Cases are all wired with Admore lights that function as running, brake and turn signals. Yes it was pretty much a plug and play install if you can use simple tools. Admore furnishes very good instructions.
