Installed LED Headlights & now Hi-Lo Flash won't work! Any others? Fixes?
Don60
Hello, I have a 2020 F3 basic Spyder and have updated my headlights to LED. I had taken it for granted that the light flash switch on the left side worked to give others a chance to pull in the front of you, but find that it does nothing, high or low beam! Anyone else have this issue? Any fixes?
On the older RT’s the high low was a flipper. If it’s the same you probably jammed the converter box that’s attached to the LED against the flipper and it can’t move. Take the back cap of the headlight off, pull the wires all the cables, boxes etc out and let them dangle out and try it.
Ok, will look at doing that! Will have to remove windshield and some panels to get to headlights! Not to hard, just time consuming! Thanks for your response.
