Installation of RT shocks on 2011 RS Spyder
blambert
Folks,
Just purchased some used RT front shocks for my 2011 RS ( I also have installed the Baja Ron sway bar). Any tips of the trade for removing my old RS shocks and installing the RT front shocks.
Regards,
Lambo
Put zero mileage RT shocks on my '08 GS/RS a few weeks ago. Piece of cake. Only recommendation I'd make is to wear gloves when you're using that crazy adjustment wrench. I didn't and scraped my hand on the cove of the "A" support. Peeled a little skin off. Running mine at 4 without the sway bar. With sway bar, I understand 3 should be sufficient unless you ride 2-up a lot.
The swap is straight forward. Remove the bolt at each end of the old shocks. Replace with the new shocks. I don't remember the torque setting on the shock bolts. Having a jack will help ease the alignment of the bolts with the holes. I have a sway bar and set the RT shocks on 5. I like stiff suspension, ride two up a lot and often pull a trailer. Good Luck with your swap. :thumbup:
You might have to do some jigglin' & wigglin' to get the old shocks out from within the a-arms... Try to remember that little dance because it'll help with getting the new shocks into their new homes... :thumbup:
When installing new shock, put the top bolt in first and then lower the jack (or lift the wheel) until the bottom bolt lines up. Piece of cake install. :thumbup:
Tip
Put a wheel bearing grease on the nut and bolt, it keeps the hex end of nut and bolt from damage. When putting it back together put a light synthetic oil on the threads, keeps them from rusting.
That's IMHO.
Mike
That's IMHO.
Mike
If you add oil to the threads, do it after you have torqued them. JMHO
