RickD
I picked up A PAIR of LED DRL's (sold in pairs only, you will only need one), handlebar switch and relay/harness kit from Amazon, about $40.00 plus tax.  They are actually quite bright and look very good IMHO.  I wanted a handlebar switch and relay wiring for future additions.  I picked up a +12v trigger off the USB charging port.  You can forego all that trouble and expense by simply wiring the light to a DRL control module (about $12-20 on Amazon).
NOTE: This mod requires drilling two small holes in the front facia for the mounting bolts.
Things I had on hand you will also want:
M4 x 16 (2) bolts with nuts (slightly larger may also work, but be careful of the length)(the bolts furnished with the DRL are too short);
Suitable stainless flat washers (12)(10 used as spacers to raise the DRL up off the front facia a little);
Piggy-back spade connector and crimp-on spade connector for the trigger/switch wire if you want to trigger the relay off the USB port.
I think the pictures are pretty self explanatory.
