New 2012 rt se5 limited bought new July 2013, 5700 miles serviced at dealer, the latest problem on very slow to up shift and when it does it jerks you back, some times it takes multiple tries, also hard to get it to manually to down shift, and when it does the engine rpm increases causing it to leap forward almost pushing me into on coming traffic if I had not gotten on the brakes and ran off the road, also was stuck in 4 th as I let it auto down shift at a complete stop showed in forth had to manually downshift and goose the throttle to get it to down shift. If my wife had been riding the outcome would have been worse.
so does anyone have any ideas also the previous issues were blowing horn fuses, then compressor went out, handlebar problems, left front wheel bearing and a belt noise they still can't find the problem, the last belt fix was belt grease from brp, I'm a bit uneasy with this spyder, so any ideas
