I have had electrical problems with my RT-S since it was delivered. Has had battery replaced twice. Sometimes will not power up when key is turned on. Has had unexplained fault codes. Some of the lights in instrument cluster do not work . Dealer replaced instrument cluster, light still out in cluster. Dealer talked to BRP tech support yesterday and BRP said to replace the ignition switch and lock on trunk. Appears they have had a problem with some switches key code search function not shutting down when key is removed. This draws power from battery and kills the battery after a few days when bike is not run. Thought that was great, finally will get this problem fixed . Well today dealer called and said no switches in stock and none on order. Dealer called BRP and got the same story no planned date when these switched will be available . Dealer asked BRP how was he going to fix my RT if this part is not available . BRP rep said he did not know. Told dealer he would call back tomorrow. I am starting to get real frustrated with all this. This is unbelievable . I have never heard of a company that did not have parts to repair a new vehicle. Just totally amazed. Anyone else have a similar experience?
