mtdoragary
My Harley runs much cooler than my Spyder and is much more comfortable in hot weather. I can't say the same for my other air-cooled bikes with the exception of my old Beemer R60US.:agree:
The amount of coolant in any heated system determines 2 things, first time to reach operating temperature after initializing the staring sequence and second, the maintaing of a "calculated" temperature range as determined by engineers in their op-specs ("thermo-hydrodynamics" fancy word for heating and cooling by use of a moving fluid).
ANY changes to "cooling" down the engine has an offset on the other side of the equation (ie: balance between time to reach initial warm-up temp versus a reducing lifetime of a component not at temp.).
PERSONALLY I want a ride that does not try to bake me regardless of outside temp. Unfortunately motorcycles do not have a "firewall" which both contains and deflects engine heat (and fire) away from the occupant(s). But liquid-cooling of an engine beats air-cooling any day!
Just some food for thought!
