I pod nano ?
wa3wheels
I am wanting to upgrade from the 2nd generation I pod to the I pod nano. Has anyone tried the Nano on a 2010 RT I Pod acc. Plug in? The 2nd gen. I Pod plays but does not appear on dash display.
The Premiere Edition RTSs that were pre-ordered came with a 5th Generation Nano. I love it! :thumbup: I suspect the newest Nano would also work very well, but I have not tried one. They are about half the size of the 5th Gen. If you get one, be sure to get a screen protector and a case with a screen cover. I doubt banging around in the cargo compartment would do the touch screen any good.
I Pod Nano
Shall give it a try, Apple Store has 15 day return policy.
Thanks again Scotty,
wa3wheels
iPod nano 3rd gen
I have one and it works great on the 2011 RTS. Everything shows up on the display.
i use a ipod nano on my 2010 rts limited and it works great
Here's hoping the next gen shuffle has the ipod connection. That would be perfect for the trunk. I have the latest Nano as well, works fine.
Ipod
My 2011 RT came with an iPod connector as well as a headphone connector. iPhone and iPod work fine but since the iPod Shuffle uses only a headphone connector, it won't let you change songs or playlists. Went back to using iPod.
Exactly why I wish it had the ipod connector!! No screen to worry about to boot!!!
Think of it as the "Forrest Gump" of mp3 technology. Fill 'er up, hit random, and see what happens. I have the Rolling Stones top 500 on my shuffle, really interesting sitting at a light with Ememin and then switching to Janice Jopling or Beatles:D
Ipod 4th generation Nano
Use the Ipod on 2011RT Works great. Just get a case and Velcro to side of trunk. Stays in place and out of the way.
iPod 6th Generation Nano Question
On my 2010 Spyder RT- S
I have just upgraded to the 6th Generation iPod Nano
I have fitted into my rear trunk using the Can - Am supplied iPOD cable
It works fine with the display and chargers up ok
Afer my ride I have just tended to switch the Ignition from the Spyder off and leave the iPod connected in the trunk
My question is - When the power is switched off from my Spyder Does this switch the iPod off as well or do I have to manually
switch the iPod off - The screen of the iPod is off but I'm not sure if the music is still running in the background and if it is
would this do any long term damage to the iPod
Perhaps there is a setting on the iPod that will switch it off once power from the cable is off - If so does anyone know how to set the
iPod to go off once the power from the Spyders ignition is off
Eddie Sheppard
Reading UK
Spyder – RT-S SES (AUTO 2010 Model)
List of Mods :-
Added Zuno 660 -Garmin kit as supplied on the Spyder RT Limited
Digital Voltmeter and Digital Clock to replace Fuel and Temp gauge – Fuel and Temp now
displayed in Cluster Display
LED Bulbs Reversing Lights,Front position lights
HMT - Brake Light
LED – Running lights
LED - Mud Flap lights
Rear extended Mud Flap
Sport Tall Wide Clear Windshield
Chrome 2011 Front Lower Wind deflecors
Utopia Backrest
S/S Seat Prop
S/S Handlebar Weights
S/S Grills both sides matching
Bottom Panel S/S Protection
S/S stronger Funk Lid brackets
S/S Bracket for RBNS Hood for Zumo 660 GPS + TourTech Lockable Mount
Rubber Tank protector on glove box
Grip Puppies
Power Socket in Switch Cluster and at Rear passenger Handrail
Rear Speaker Switch for passenger On/OFF
Upgraded Front Marine Speakers
Bluetooth On board Radio to Sena SMH10 Headsets
Not sure if it works the same, assume it does, but I have a 2011 RT-S, use a 1st Gen iPod Touch, and it goes into standby mode when the key is off. Once the key is off, no power goes to the unit and it consumes battery life same as it normally does in this mode. When the key is turned back on, it resumes charging and plays the song where it left off (assuming it has not been unplugged from the cable).
The iPod (at least my Gen 5 Nano) goes into standby (off) mode when the key is turned off, and it charged though the iPod cable. When you start back up, it resumes right where you left off.
Just to clarify, the iPod does not power down and the :spyder2: does not continue to charge thru the iPod adaptor when the key is turned off. The only time any iPod/iPhone/iPad unit is powered down is when you hold the standby button in for a few seconds and an option will come up on screen requiring you to swipe it to power down. Otherwise, the units will continue to consume power, so don't be surprised if your iPod battery shows less life after leaving it sit for awhile.
What you say is puzzling. I'll agree that the unit goes into standby instead of a true off, but it does seem to charge. I have put mine on the cable, with a partial charge, and it has a fully charged battery the next day without running the engine. I have also left it in the Spyder for weeks at a time without riding, during the winter, and it maintained a charge. If left on the countertop for that amount of time, it will go dead. Maybe there are differences between different iPod models, or maybe I'm just lucky? :dontknow:
That's interesting Scotty - perhaps you're right and that it may be different for the various iPod models. Good to know though, since this could be someone's issue with battery drain.
The Missus just cam ehome with an early Christmas present for the RT... An Ipod! :thumbup:
Of course I just dumped the music that I had in the computer into it and haven't even looked at the manual yet... :shocked:
Wish me luck!
