I need some real advice about trailer hitch install, please help
the adapter adapts from a 9 pin brp to a 4 pin flat which is the trailer side...it is called a 4 pin trailer adapter harness...if i am reading the box right, which i have right in front of me, i am not sure which number you need..pkg number is..280400060...p/n number.. is...219400271...it is a kit that includes 2 safety cables and a mounting bracket...hope this helps you out..
To quote the 2013 Accessory catalog...
4 Pin Trailer Adapter Harness
Designed to convert RT-622 trailer's
elecrical harness to a standard 4-pin trailer
connector for automotive use.
RT-622 2013 219400437
$64.99
RT-622 2012 and prior 219400271
$144.99
This will not adapt a 4-pin trailer to the Spyder connector...the plugs are the opposite gender. I take it you have not tried to use this yet.
Isn't this the cable that the connects the BRP trailer to a cars 4 pin flat connector? :dontknow: I think we are looking for is a 9 pin to 4 pin that connects from the RT to the non BRP trailer.
