troop
Well-known member
I initially had installed Helibar's on my 2022 RT S2S. After I had a seat redone by Russell Day Long, my ride height increased by approx 1". I found my bars to be too low for my 6'3" height. I then dug out my previously used Lamonster 2" riser plate to try. Obviously, my cable length was too short. This was even after I'd previously removed the upper metal cable clip (accessed by removing plastic ignition cover plate) and clipping a cable zip tie when I had my right side panels removed for wiring my Zumo XT2.
I then saw a video posted by Pierre (Can Am Accessories) of him installing his 7" Longhorn handlebars (pretty cool BTW). In this video, he showed how to access extra cable length by removing the right side lower speaker cover and pulling loose some extra cable and clipping another zip tie. After doing this, I gained at least another 2" of cable slack. Sooo, back to my parts box for the Lamonster 2" riser.
Success!!! 2" riser plate + Helibars = approx. 8" of handlebar height! I was able to fit my Garmin Zumo XT2 GPS/Touratech locking mount forward of the bars using a RAM 3" socket arm. I have the bars as forward as they go. I also elongated the pin hole a touch to get a bit extra forward movement, as I was looking for extra height, not for the bars to be closer. Works well
