So I just installed the handlebar risers from SlingMods on my 2021 RT-L. They are made by Show Chrome.I had a few concerns and was wondering if anyone else ran into this or knows of a fix. First I tried the riser blocks with the 2 spacers they give you. I removed one of the spacers because I could not feel the threads of the bolts coming through the bottom clamp so I did not trust not having the threads going at least flush with the lower clamp. The other concern was with the control cables. They are tight, especially when turning. Removing that 2nd spacer helped a bit but not 100% happy with the tension. Does anyone know if there is a way to get some extra slack in those control cables? The install video on SlingMods sight shows plenty of extra cable on the F3 that they did the install on.
